4 members (Forty9, MaxStewart, Wally / Montana, 50Chevy3100), 89 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
WE ARE GETTING READY TO GET THE BODY OFF OUR PANEL BUT I NEED TO KNOW HOW TO GET THE STEERING COLOM OFF SO IT WILL COME THROUGH THE FIRE WALL
Take the steering wheel off, remove the pitman. Remove the clamp from the dash. After thats loose take the three or four bolts (can't remember how many) that hold the steering box to the frame off then slide it out. That should be all best as I can remember.
Bruce
My Trucks
Stuff I Collect
What year panel?
If this is an Advance Design truck the column does not separate from the box in a way that can be reasembled. Its better to remove the box from the frame and pull the column out the bottom.
The only time I've removed a body without first removing the column I removed the body one piece at time using a sawzall, and that's probably not what you have in mind.
3B Offline
Hy fire12, please remember to tell us what year/size of truck you are asking questions about in your posts. If this question is about the 49 panel in your profile, then you must remove the steering wheel, upper columb support, the horn wire, the floor trim piece, and then you can either remove the pitman arm from the steering box, or the drag link from the pitman arm. then remove the bolts which hold the steering box to the frame, and remove the steering box out from under the truck. You will have to jack the truck up quite a bit to get it out, hope that helps, and Happy New Year
THANKS GUYS FOR THE GREAT INFORMATION I WILL DO IT ON FRIDAY
As they have said it's best to remove it box and all from the bottom.
If you really want to you can remove the body from around the column, this is how I've done it before, but the body has to go up pretty high and you have to have everything just right, and move the truck forward or body back as you go up.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I agree with everyone's suggestions on the steering column removal on the AD Chevy truck. I have one more addition to the "how to" list: If the engine is still in the truck, you will need to remove the driver front wheel and also remove the inner fender panel to get the column out. That's what I had to do on my '48 1 ton pickup.
