| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 23 | WE ARE GETTING READY TO GET THE BODY OFF OUR PANEL BUT I NEED TO KNOW HOW TO GET THE STEERING COLOM OFF SO IT WILL COME THROUGH THE FIRE WALL | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Take the steering wheel off, remove the pitman. Remove the clamp from the dash. After thats loose take the three or four bolts (can't remember how many) that hold the steering box to the frame off then slide it out. That should be all best as I can remember.
Bruce | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What year panel?
If this is an Advance Design truck the column does not separate from the box in a way that can be reasembled. Its better to remove the box from the frame and pull the column out the bottom.
The only time I've removed a body without first removing the column I removed the body one piece at time using a sawzall, and that's probably not what you have in mind.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fire12, please remember to tell us what year/size of truck you are asking questions about in your posts. If this question is about the 49 panel in your profile, then you must remove the steering wheel, upper columb support, the horn wire, the floor trim piece, and then you can either remove the pitman arm from the steering box, or the drag link from the pitman arm. then remove the bolts which hold the steering box to the frame, and remove the steering box out from under the truck. You will have to jack the truck up quite a bit to get it out, hope that helps, and Happy New Year | | | | | Joined: Dec 2008 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 23 | THANKS GUYS FOR THE GREAT INFORMATION I WILL DO IT ON FRIDAY
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As they have said it's best to remove it box and all from the bottom.
If you really want to you can remove the body from around the column, this is how I've done it before, but the body has to go up pretty high and you have to have everything just right, and move the truck forward or body back as you go up.
Grigg | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I agree with everyone's suggestions on the steering column removal on the AD Chevy truck. I have one more addition to the "how to" list: If the engine is still in the truck, you will need to remove the driver front wheel and also remove the inner fender panel to get the column out. That's what I had to do on my '48 1 ton pickup. | | |
