Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 93 guests, and 5 robots.
Topics128,281
Posts1,058,469
Members48,490
#488519 01/01/2009 1:53 AM
Does anyone know the what to set the valves at when the engine is warmed up? I checked the maintinance manual and it says to refer to the sticker on the valve cover. After 60 years that sticker is long gone... I saw it said to set them cold at .012 and .020 but to re-check after the engine warmed up.
Thanks.
It just says to adjust valves to proper clearance after engine has warmed up on p 220 of maint. manual. If it is not specified other than .012 and .020 in the manual, I bet the same values were listed on your missing decal.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
From the Thompson tuneup manual that I have It has for the first series engines .006 to intake and .013 for exhaust hot, second series engines, after serial number 228-87569, the settings are .012 for both intake and exhaust hot.
1936 GMC T-14 1/2-Ton Pickup
