| | | Forums66 Topics128,281 Posts1,058,467 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | Does anyone know the what to set the valves at when the engine is warmed up? I checked the maintinance manual and it says to refer to the sticker on the valve cover. After 60 years that sticker is long gone... I saw it said to set them cold at .012 and .020 but to re-check after the engine warmed up.
Thanks.
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | It just says to adjust valves to proper clearance after engine has warmed up on p 220 of maint. manual. If it is not specified other than .012 and .020 in the manual, I bet the same values were listed on your missing decal.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2003 Posts: 316 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 316 | From the Thompson tuneup manual that I have It has for the first series engines .006 to intake and .013 for exhaust hot, second series engines, after serial number 228-87569, the settings are .012 for both intake and exhaust hot. | | |
