3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#48847 08/10/2005 12:09 PM
Junior Member
Junior Member
Hi all, I would like to know if there is a database somewhere that lists swappable parts for my 1965 c-10. I've heard rumors of being able to put disc brakes all the way around, without buying one of the expensive kits. And if so what model/year vehicle is the best choice to salvage the brakes from?
#48848 08/10/2005 12:12 PM
Junior Member
Junior Member
In addition, I haven't decided whether or not to keep the 6cyl, or drop in a 327/350. Any advice on that would be greatly appreciated, thanks in advance
#48849 08/10/2005 11:42 PM
327/350 are basically bolt-in using factory V-8 parts. Using parts from a '72 to '87 you can swap disk brakes, or the entire IFS with disks to your truck.
I don't know how to do rear disks without either a kit or a replacement axle on one of these.
#48850 08/11/2005 2:16 AM
Z
Z Offline
the front brakes do most of the stopping on a pickup,so unless you want rear discs for looks id spend my money on something else.if your truck has a 230 or 250 all you need is v8 engine mounts for a v8.
#48851 08/11/2005 3:21 AM
with the 230 or 250 engine the mounts will work with the v8 just take off the steel piece between the mount and the engine and the eight will drop right in. the six mount are stronger anyway and easier to get the bolt into then the v8 type. the flywheel or flex should bolt up also with no problems. if you go to a v8 the front end will come up a little bit. the v8 weight less then the six.
super250six
