1 members (Cletus1950), 77 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
Sometimes the fix simply calls for a bigger hammer, but I fear I've used my biggest one... HELP!
I may have the mother of all fuel tank clogs.
Here's the lowdown.
3800 panel.
Clogged, rusty, 10 years of varnish, under frame tank.
Bought Por-15 tank restoration kit.
Powerwashed inside of tank several times.
-lots of crud out
Used the kits cleaning products.
-lots more crud
Did the whole "add gravel and shake with cleaner" trick"
-Lots of gravel and a bunch more crud came out.
Powerwashed again until water ran crud-free.
Followed the rest of the instructions with the kit and ended up with a nicely sealed and painted tank.
Installed tank and decided to try to blow a little air into the outlet to make sure all was well. Nothin. I puckered for all I was worth, but with no luck. I found a coat hanger and managed to get about 11 inches into the tank outlet. It came out with some traces of the familiar crud. Dang. Sprayed some carb cleaner into hole. Hole made strange "tube filling up" sounds. Packed up for the day.
Day 2
Got a compressor from work and put it in the back of a van... drove to the project truck and plumbed an air line from the compressor directly into the tank outlet. Removed the filler cap (good idea from other post here on the 'bolt) and started turning up the regulator.
20lbs
30lbs
40-50-60-70-75-80... Getting nervous.
Decided to take a walk. Came back in about 10 minutes and the pressure is SOLID at 80lbs.
Got INTO the back of the van... hid behind the compressor...
90
100... oh hell
125lbs
That's the max this compressor will deliver before the safety valve releases.
Ummmm. NOW WHAT? Any suggestions would be VERY welcome. Does anyone know of a flexable drill bit? How Long is that tube? I'd love to stop drilling before a drill bit simply poked out the bottom of my nicely re-done but very clogged tank!
This isn't something silly like a check-valve in line right?
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
Take an old speedometer cable, chuck the end into your (variable speed) drill motor, and probe the tank outlet with it. If it tries to wind up into a pretzel, it might be necessary to cut it off where most of its length is supported by the pickup tube. Spin it with the drill motor, and gently feed it into the clog. Good luck!
Good Idea!!
I'll give it a shot.
Anyone else have any Clog-busting advice?
'52 3800 Panel
-Groucho Marx
I had the same problen on a 53 sub. I screwed a grease fitting in the outlet and used a grease gun. worked great!
My Blog
why not get a new tank and not risk the future hassles and driving problems? thats what i ended up having to do on my 57 truck.
Got short chunk of 1/4" aircraft cable. Chucked it up in the drill and zipped it right through. Thanks for the advice.
Clog busted.
'52 3800 Panel
-Groucho Marx
I did the same type of resto on my 55 Caddy tank and it came out great axcept like you the outlet was now plugged. I think there was a screen filter inside the tank at the outlet and the polymer sealer sealed it up. What I ended up doing was I hooked my fuel line to the drain plug fitting and just put a plug in the outlet port.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
