5 members (Wayne67vert, Hotrod Lincoln, DadsFirstPickup, pkr, JW51), 104 guests, and 1 robot.
Topics128,048
Posts1,055,624
#48825 08/09/2005 5:45 AM
Junior Member
Junior Member
My new '54 1/2 ton is smoking blue pretty badly, its got a 55-57 261 with 235 head on it, new plugs cure the smoking for a couple of days, but they carbon up pretty badly. Could someone tell me what the cylinders should read on a compression tester?
thanks for any help, mike
#48826 08/09/2005 6:13 AM
Wet or Dry readings?
Dry test first w/ the tester, take your cylinder readings, them squirt wd-40 or ?? to seal the rings better then test again. If the reading improves it's the rings, other wise it's the valve guides.
140.
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#48827 08/09/2005 12:43 PM
When doing a compression check take out all the plugs, disconnect the coil wire, and block the throttle wide open. It sounds like you may be running an overly rich fuel mixture possibly.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#48828 08/09/2005 6:14 PM
H Online: Content
What color is the smoke, and does it use oil? Oil smoke is blue, and if the rings are bad, the exhaust will puff smoke after coasting for a distance, and getting back on the gas. Fuel smoke is black, and causes a dark black, sooty deposit on the plugs. Oil fouling is black and greasy, and will form a hard deposit on the electrodes which foul it out.
Is the plug fouling uniform from one cylinder to another, or is one or more plugs getting fouled worse? Fuel fouling generally happens to all the plugs equally.
Edit: I just noticed you said the smoke is blue. If the compression tests low, and rises when oil is put into the cylinders, you need a ring job.
#48829 08/12/2005 3:51 AM
Junior Member
Junior Member
I just did the compression test, all cylinders are around the 120 mark. Thanks for the help guys.
#48830 08/12/2005 12:41 PM
Did you do both the "Wet" and "Dry" compression test? BTW, To do a wet compression test you just need to squirt ~ 1 tsp of oil into the cylinders when you do the compression test.
#48831 08/12/2005 10:11 PM
Riding in the Passing Lane
You can have good compresion & still have bad oil rings.
1972 Chevy c10 Cheyenne Super
