4 members (Charles in CA, IHPWR, Otto Skorzeny, 1955 1 Series), 155 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#487949 12/30/2008 6:57 PM
Hi,
I've recently bought a 1961 Chevy panel truck.
LWB, 1 ton, 8 lug wheels, 8-17.5 tires.
It's a pretty decent size truck.
It came with no drivetrain,
and now I realize no parking brake!
My options I guess are:
1) Transmission that has a parking brake (Can a driveshaft brake be added to any manual trans?)
2) Try to add a cable operated parking brake to present rear
3) Swap rear for different one(with parking brake)
4) Swap backing plate and entire brake assembly from later rear onto my old rearend.
Ideas welcome!
This is a resto-rod type of build up, so I want to keep it mostly stock except for drivetrain.
The engine will be a 292 Chevy six to begin with.
Maybe a swap to a Cummins 4 cyl diesel later on.
Pete
Hi Pete...
Best bet is to look for the 4-speed transmission with the brake attached. Let me know if you need a picture; I think I can find one. I do not think the parking brake setup will fit any other transmission.
Otherwise the best bet is to change the rear end. Then you can look for a C10 brake setup. You will just need to get a longer main cable since you most likly have the 9' bed size (panel).
Hope this helps.. Russ
1960 Chevy Apache (C10)
1965 Chevy C30 Dump Truck
1966 Chevy C30 Tow Truck
