| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | I'm going to overhaul the 235 this winter, and I was wondering if anyone here knows for sure if a 261 crank and rods will fit. I haven't been able to find any, but I'm still looking.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I think that if that were the case, you would have heard of it being done, many times over. Also, there would be mention of the resulting different displacement number. My guess is that it is not a fit. | | | | | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | 261 and 235(full pressure) cranks are the same.
The rods are the same at the journal end but have heavier(larger)pin end that requires use of the larger bore 261 piston which the 235 block cannot handle.
The difference between the two engines is the bore. The stroke is identical.
If you want a 261 you will need a complete short block.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
