3 members (Nick in Manitou, UtahYork, Bill Hanlon), 78 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#4872 05/16/2003 6:00 AM
I've found two firing orders for the 235 - 153624 and 153642. Any idea which is correct?
46 GMC
#4873 05/16/2003 6:07 AM
153624
#4874 05/16/2003 6:07 AM
15 is too young...
36 is too old...
24 is just right!
(Or so I've heard...)
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#4875 05/16/2003 6:12 AM
153624 it is
#4876 05/16/2003 6:29 AM
Thanks very much - Here's another one...I've just replaced the head on my 235 and it now runs extremly rough. The plugs in 1,2 & 3 are severly carboned after running for 10 minutes while the plugs in 4,5 & 6 look like new (They are all new). The firing order was correct.Any thoughts?
46 GMC
#4877 05/17/2003 4:46 AM
check compression and manifold heat spring. Its weird that #3 and #4 would be so different, because they share an intake runner. A 235 has siamesed intake ports, so 1&2 , 3&4, 5&6 share intake runners. Check plug wires. Check valve adjustment. Check timing. That should point in the right direction
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#4878 05/17/2003 5:11 AM
The only thing I can think of is bad rings or valves in those cylinders. Do the heat ranges on all the plugs match? if some are too cold, the excess soot wont get burned off. Thats the only thing I can think of.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
