9 members (dt235sd, Gdads51, Gib70, 3B, Phak1, 32Fordpuchoptop, 68ironhead, Jon G, 2-Ton),
79
0
Mod | | | Forums66 Topics128,049 Posts1,055,693 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | I've found two firing orders for the 235 - 153624 and 153642. Any idea which is correct?
46 GMC
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | | | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | 15 is too young... 36 is too old... 24 is just right!
(Or so I've heard...)
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | Thanks very much - Here's another one...I've just replaced the head on my 235 and it now runs extremly rough. The plugs in 1,2 & 3 are severly carboned after running for 10 minutes while the plugs in 4,5 & 6 look like new (They are all new). The firing order was correct.Any thoughts?
46 GMC
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | check compression and manifold heat spring. Its weird that #3 and #4 would be so different, because they share an intake runner. A 235 has siamesed intake ports, so 1&2 , 3&4, 5&6 share intake runners. Check plug wires. Check valve adjustment. Check timing. That should point in the right direction
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | The only thing I can think of is bad rings or valves in those cylinders. Do the heat ranges on all the plugs match? if some are too cold, the excess soot wont get burned off. Thats the only thing I can think of.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
