Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 132 guests, and 4 robots.
Topics128,283
Posts1,058,505
Members48,490
V
V Offline
Does any one know if you can bolt the NP 205 transfer case to SM 420 tansmission.
no there was never a factory setup like that
but a divorcid setup would be posible
Advanced Adapters might have an adpter to do a married unit
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
V
V Offline
Thanks i will check it out
ALSO CHECK OUT WWW.NOVAK-ADAPT.COM THE ADAPTER WILL PROBABLY BE FOR A JEEP TRANSFER CASE WHICH ARE STRONG ENOUGH FOR MOST APPLICATIONS. THEY ALSO HAVE A LOT OF GOOD TECH INFO ON THEIR SITE.
Insert clever statement here:
Junior Member
Junior Member
I was looking for a place to post this and this seems to be the best place. oldchevy46, I get the feeling you might be able to answer these. I'm new to the truck world and I'm looking at buying a 1970 4x4. I'm trying to find out what transfer case(s) were avalible in the 1970 4x4's. Is the NP205 the only one? The vehicle I'm looking at is a 3/4 ton with a 292 and a 4 speed. It looks like a NP205; however, as I said I'm new at this.
Next question, the truck appears to be geared extremely low. If I were to buy it I'd be looking to improve this for every day use inlcuding highway use. Is the low gearing a traight of these trucks or can I assume this particular truck may just have extremely low gears. I have not found another 1970 to drive and compare it to.
Thank you for your time
JN
V
V Offline
i dont think the 205 series transfer case came out till later around 77or78 but dont take my word on that.
