0 members (), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,454
#486314 12/25/2008 6:47 PM
I need to change the oil in my compressor and the manual calls for a "Air compressor oil such as SAE-30". It is a Craftsman Two Stage. Would it hurt to use a synthetic oil or should I stick to the basic SAE-30.
Use the compressor oil or 30W non-detergent oil.
'67 GMC 3/4 292 4spd
We used 30 wt non detergent for many years because that is all we had. We now use synthetic because synthetic oil is so much more tolerant to moisture than petroleum based oil. Spend the extra money for synthetic. This is a good one http://www.grainger.com/Grainger/items/1WG49
Ex Hall Monitor
Ex Hall Monitor
I use IR synthetic compressor oil.
Leo Offline
Moderator
Moderator
I have a Campbell Hausfeld compressor and so I get their brand of compressor oil.
Knowing Sears you better stick with their oil! They can be #$%^**** at times. If you have a warrenty on it.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
DonG: would you believe I went into Sears a few months ago and they did NOT have any compressor oil on the shelf. I have their professional grade 80gal/7hp/175psi/18cfm compressor and would think they would keep oil in stock. The compressor has ran well for over 6 years but I would like to change the oil!!! smile
Ex Hall Monitor
Ex Hall Monitor
Check you local farm store Alvin. The fact that Sears doesn't stock it doesn't surprise me.
I'm with Tiny - Try Tractor Supply. Even Lowes and Home Depot caries it (although they charge more)
Do you want me to check here for you? Can't they order it in for you or are they to lazy.
62Blue
Don
62Blue
62Chevy in progress
Don: I think they are both lazy and don't want to. The local Sears here was a nice repair center for over about 35 years and I enjoyed going in their for parts, repairs and what have you....but that all changed about a year ago and its gone to heii in a hand basket!!
I can drive over to Greenville if I need to but I'll just go down to Total Compressor place and get some...or tractor supply is only about 6 or 8 miles from me.
thanks for the offer.
Moderated by  MNSmith
