5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
I am installing a fenton dual intake on my 235 and am having trouble finding a matching pair of rochester carbs. Are there any modern options that will fit the flange size (2 15/16").
Thank you
It's a work in progress! Started August 08. gotta finish before the baby comes August 20th!
https://picasaweb.google.com/tomnmindy/Truck?authkey=Gv1sRgCOj0gsiF6ZCDKQ&feat=directlink
Tom Langdon will give you good advice. Maybe people here will post their personal experiences with dual carbs on a 235.
I'm running Langdon's Carter/Weber setup on my 235 and have a number of pictures in my Webshots that document the install. They might give you an idea of what it takes to get his setup installed, synced and tuned.
The cost is reasonable, the hardware is well thought out and all of the shortcomings of a 50 year old carb, are eliminated. I've run up over 7000 miles on the C/W setup.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
This is as modern as I know of http://www.mooneyes.com/MISC/drive.html
you can get rebuilt carbs from auto zone.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Riding in the Passing Lane
Have you put an ad in the Parts wanted section of the Swap Meet?
1972 Chevy c10 Cheyenne Super
Thanks everyone. I will do some checking. I've seen a few used carbs but they are in pretty poor shape. I am willing to invest more in a modern setup but want to use the fenton dual intake. I heard from someone that demon made a single barrell carb that would fit but can't seem to find it anywhere.
Hey FLA54CHEVY-
Thanks for the webshots..I have a post questioning if the stock intake can be used with Cliffor=d headers..ie. removing the stock exhaust manifold. It looks like thats whaot you did basically. Is that a stock intake?
Keith
Domon isn't making singles, or at least not yet. They are making 2 bbls loosely based on the Stromberg 97/Holley 94 though.
I will throw another option for you, though. The Holley Model 1904. It's mainly a Ford/International carb, but I have seen them on GMCs, too. If you use the Ford/International version (or V6 GMC), the throttle arm will be on the wrong side, but can be modified to work wit a Chevy intake. Re-jetting is easy, too, as the jets are the same as a modern Holley 2 or 4 bbl.
Bill Burmeister
