9 members (TUTS 59, cmayna, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost, tclederman),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48677 08/04/2005 6:27 AM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Hi everyone, 2 weeks ago i purchased a 66 swb chevy. Truck has a 305/350 from a 78 monte and i was wondering if there is anything i can do to fix the linkage so i get the correct amount of movement on the shifter arm so that i dont go from park to 1 in half of the normal travel(ie; reverse shows barely on the right side of park, drive shows in the neutral area) It's not a super critical thing, but annoys me anyhow. Thanks! Shawn
1966 SWB
#48679 08/04/2005 10:42 PM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | You need to increase the length of one of the lever arms between the column and the trans, or the lever at the trans itself. This will make the shift lever move further between quadrant notches, and align better. Jerry
#48680 08/05/2005 9:55 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are using the stock column with the dial on top sometimes you have to loosen the clamps holding the column & turn it. Then readjust the linkage rod. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48681 08/05/2005 11:42 PM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Hotrod has it right. it's the amount that the dial and shifter arm moves. I'll get under there and see what i can do. thanks guys!
1966 SWB
