6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#48677 08/04/2005 6:27 AM
Junior Member
Junior Member
Hi everyone, 2 weeks ago i purchased a 66 swb chevy. Truck has a 305/350 from a 78 monte and i was wondering if there is anything i can do to fix the linkage so i get the correct amount of movement on the shifter arm so that i dont go from park to 1 in half of the normal travel(ie; reverse shows barely on the right side of park, drive shows in the neutral area) It's not a super critical thing, but annoys me anyhow. wink
Thanks!
Shawn
1966 SWB
#48679 08/04/2005 10:42 PM
H Online: Content
You need to increase the length of one of the lever arms between the column and the trans, or the lever at the trans itself. This will make the shift lever move further between quadrant notches, and align better.
#48680 08/05/2005 9:55 PM
Riding in the Passing Lane
If you are using the stock column with the dial on top sometimes you have to loosen the clamps holding the column & turn it. Then readjust the linkage rod.
1972 Chevy c10 Cheyenne Super
#48681 08/05/2005 11:42 PM
Junior Member
Junior Member
Hotrod has it right. it's the amount that the dial and shifter arm moves. I'll get under there and see what i can do. thanks guys!
1966 SWB
