0 members (),
106
0
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | I have the the motor and trans in the frame on my 51 GMC can I fill the transmission SAE 90 WT oil through the shifter tower, sure would make it easy ??
Thanks Steve
I am going nowhere fast and it's not taking me long to get there !!!!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
Sure seems like a easy way to do it to me. Be sure to pull the side plug so you get some idea of the proper 'full' as the lube begins to leak out.
Stuart | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That is the easiest way to do it! Remove the side plug, fill from the top and go real slow on the last little bit so you don't overfill it, and if you do overfill let it sit with the plug out so it dribbles out to the right level.
Grigg | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | great, thanks, the trans was drained totally when I removed it, the manual says 6 qt's so I'll start with about 5 and see what the level is on the side plug ,, Merry Christmas !!
steve
| | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Check that specification again- - - - -I'd be very surprised if that's not actually 6 pints- - - -not quarts. I can't imagine that trans holding 1 1/2 GALLONS of lube! Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes, it,s 6 pints or lbs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | Its 6 pints , sometimes I cant type what I am thinking,,
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You too????
