4 members (TexasJim50, RLB, GIJOE298, Otto Skorzeny), 61 guests, and 2 robots.
Topics128,154
Posts1,056,851
Members48,456
I have the the motor and trans in the frame on my 51 GMC can I fill the transmission SAE 90 WT oil through the shifter tower, sure would make it easy ??
Thanks Steve
I am going nowhere fast and it's not taking me long to get there !!!!
Steve,
Sure seems like a easy way to do it to me. Be sure to pull the side plug so you get some idea of the proper 'full' as the lube begins to leak out.
Stuart
That is the easiest way to do it!
Remove the side plug, fill from the top and go real slow on the last little bit so you don't overfill it, and if you do overfill let it sit with the plug out so it dribbles out to the right level.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
great, thanks, the trans was drained totally when I removed it, the manual says 6 qt's so I'll start with about 5 and see what the level is on the side plug ,,
Merry Christmas !!
steve
Check that specification again- - - - -I'd be very surprised if that's not actually 6 pints- - - -not quarts. I can't imagine that trans holding 1 1/2 GALLONS of lube!
Riding in the Passing Lane
Yes, it,s 6 pints or lbs.
1972 Chevy c10 Cheyenne Super
Its 6 pints , sometimes I cant type what I am thinking,,
Ex Hall Monitor
Ex Hall Monitor
You too???? grin
