0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 4 New Guy | | New Guy Joined: Dec 2007 Posts: 4 | I've got a 1946 3/4 ton cab and was wondering about putting it on a 1949 3/4 ton frame with 1949 long-bed. Is this possible without cutting? Or, can I just bolt on the '46 cab?
Thanks Rusty | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I have a '46 and a '53, and looking at the bodys visually it doesn't look like it will work without some cutting. But, i will get a tape tomorrow and check it out for sure if someone doesn't chime in and get you a definite answer. Cecil......... | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | AD frames are wider than art deco frames. | | | | | Joined: Dec 2007 Posts: 4 New Guy | | New Guy Joined: Dec 2007 Posts: 4 | I have a '46 and a '53, and looking at the bodys visually it doesn't look like it will work without some cutting. But, i will get a tape tomorrow and check it out for sure if someone doesn't chime in and get you a definite answer. Cecil......... Thanks Jimmy, I appreciate it. Rusty | | | | | Joined: Dec 2007 Posts: 4 New Guy | | New Guy Joined: Dec 2007 Posts: 4 | AD frames are wider than art deco frames. AD = Advanced Design.... Do you know the differences? I'm still searching for the #'s. Thanks Rusty | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rusty, AD = Advance-Design (1947 to 1955 first series). There is no "d" on the end of Advance. Art Deco is a common name of the earlier trucks but not an name officially used by GM The 1946 models were sold into 1947 but were called 1946 by GM. What differences do you want to know? The seats on A-D trucks are 8" wider and the cab mounts are different. 51 Jimmy would be your best source of first-hand information about how the cab mount differences, and if your older cab will be outside or inside the frame rails. Here is a GM article about changes in 1947 compared to 1946. Tim | | | | | Joined: Dec 2007 Posts: 4 New Guy | | New Guy Joined: Dec 2007 Posts: 4 | Thanks Tim, I haven't been on in a while. I appreciate the info, and am checking out the article now.
Rusty
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | All of the frame dimensions for the AD series truck are available in the Salesman Truck Data Book (1949 is a common one you see). They are expensive both original and copies but they have lots of details. If you can lay your hands on one of those it should help with actual dimensions. | | |
