| | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | i am wiring a 52 3800, is the old 6volt headlamp switch tuff enuf for the 12 v anyone with practical advice as this is a strtch for me, going to start in the morn i have a 12 alt hooked up and am trying to head off any problems, thanks trying | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Ive changed all 3 of my trucks over to 12v. I left the wiring alone,,just changed the bulbs,generator,voltage reg.,coil,left the starter alone,and put a reducer for the gas gauge, and heater motors. Good Luck, Marty | | | | | Joined: Dec 2006 Posts: 16 Apprentice | | Apprentice Joined: Dec 2006 Posts: 16 | Dear Trying;
Yes it will be just fine.
Just follow what Marty said.
Good luck.
"There are no shortcuts to any place worth going"; Anon....
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | trying,
There should be no problem. When you double the voltage...6 volts to 12 volts, you cut the current in half, so that means your headlights will draw only half of what they did before, or to look at it another way, your headlight switch is now 'super duty'.
Be sure to swap all the lamps to 12 volt versions! Have you read the Tech-Tip on this conversion? Look at the top of the page and you'll see the link, it's worth reading.
Stuart
| | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | thanks again for the help,trying | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | This gets discussed a lot. A search will turn up hours of reading.
