3 members (klhansen, fonz8261, carbking), 98 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#484138 12/19/2008 9:48 PM
Apprentice
Apprentice
I havea 70 C-10 with a 350. Plan on putting on an Edlebrock Performer 600CFM carb. Which edlebrock intake would be the best? Also would like a mild cam like an Rv cam, which is the best for normal use? Thanks
Definitely use a dual plane manifold if you're building a street machine. The single plane types, with all the runners coming off an open chamber right under the carb, is for high speed only operation. Dual plane manifolds give better low end torque.
I've had very good luck with the Comp Cams 260H High Energy cam. It's got a very slight idle lope, almost like a stock engine with one bad plug wire. It also works OK with stock compression pressure. The next step up, the 268H, has a noticeably lumpy idle, really should have a bit more compression than stock, and doesn't play well with a stock torque converter stall speed or power brakes.
you're using an edlebrock performer carb,why not just go with a performer intake and performer cam and lifters.supposed to be dyno matched .sounds like a no brainer.my .02..............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Ditto to what Hotrod Lincoln said.Forget about an RV cam they are for motorhomes.Another cam choice would be Isky 272H.I had one of these.Very good
BC52 #484649 12/21/2008 2:54 AM
I am dead set against Comp Cams. Extremly hard on valve trains.
Noisy as well. I like Isky, Crane and Lunati. Don't overcam it.
Follow instructions to the "T so you don't wipe out a lobe.
If you are looking for some good HP check out the Vortec head thread
Call your favorite cam company with the rest of your specs and ask for their suggestion. I know what I would run, but that's from a lot of trial and error, and my preferences may not be yours. Definitely go dual-plane with the manifold. You'll gain much bottom end compared to a single plane.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
