0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48417 07/31/2005 3:59 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I changed the oil in my '51 and every time I start the truck, the oil gauge gets pegged at 60lbs. After the engine gets nice and warm, it starts operating as normal. I'm using 20-40 oil. It stays pegged until the oil gets real hot. Whats going on? Do I need to go to a 10-40? Cecil........ | | |
#48418 07/31/2005 4:52 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Does it have an over-pressure relief valve? | | |
#48419 07/31/2005 5:23 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I've never heard of a relief valve. I have a 228 GMC engine. Where would that valve be located if I had one? Cecil........... | | |
#48420 07/31/2005 5:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That valve he is refering to is built in the oil pump & is in the oil pan. You could put a master gauge on it & see how high it acually goes. I would go to a lighter weight oil like 10-40 or 10-30 if your engine is in good shape.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48421 07/31/2005 5:59 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You'll find a lot of opinions on oils if you run a search but most agree to use a single viscosity oil in these old engines. | | |
#48422 07/31/2005 10:02 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | going to a 10-30 or 10 40 oil should help.you will normally have higher pressure when the engine is cold as the oil will thin after it reaches operating temp. | | |
#48423 08/01/2005 1:27 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Straight thirty weight would make the cold oil pressure even higher than the 20W-40 being used, but I think the relief valve should come into play before the pressure pegs, regardless. Too high pressure can erode bearings, Wrenchbender may know what constitutes too much.
Baldy | | |
#48424 08/01/2005 7:12 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Now you guys really have me confussed. What if I go to a 10-30 like V6 jimmy says? I thought I understood oil viscosity, but apparently I don't. I thought that if I used 20-40 the oil would be thin when cold. Thats when its 20wt. As it warms up, it would become thicker because the viscosity changes over to 40wt. Cecil..... | | |
#48425 08/01/2005 6:34 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Cecil-
If you use 20W-40 oil, it is 40 wt cold and 20 wt hot. The "W" after the first number refers to the viscosity at 120 degrees F. The other number is the viscosity at 32 degrees F. Oil cannot thicken as it warms up. So, that said, straight 30 wt will be thinner on start-up, and thicker at operating temp.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#48426 08/01/2005 9:12 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | fab51,
Your last sentence is backward. Straight weight oils thin out as they heat and the lower the number the thinner they are. The multigrades would flow similar to a straight weight oil at the first number, ie. 20W, at lower temperatures and flow similar to the second number, ie. 40, at higher temperatures.
Baldy | | |
#48427 08/01/2005 9:41 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | As I remember, multi-grade oils are measured as follows...in the case of say, 20W-40. The first viscosity is measured at 0 F which is denoted by the "W" for "winter". The next viscosity is measured at 210 F. The oil doesn't become thicker, but because of it's high viscosity index, it measures as a SAE 40 at 210 F.( it doesn't thin out as much as a low VI oil at the same temp). This is a slippery subject.
Stuart. | | |
#48428 08/01/2005 10:29 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All those numbers get confusing. I would put a master gauge on it. Your dash gauge may not be accurate. If it goes up beyond 60-70 pounds I think you should go in & check the pressure relief valve & see if is stuck. Otherwise I would go to a lighter weight oil. I like to use as thin as possible as long as the engine sounds good & doesn,t smoke or burn oil. It seems like those old Gimys always did carry a lot of oil pressure.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48429 08/02/2005 12:55 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | it really doesnt sound like a big problem 60 psi cold isnt excessive pessure my 250 runs 60 psi hot going down the road and 40 at idle but it has a melling Hi Volume pump | | |
#48430 08/02/2005 2:41 AM | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | Hey, I'm happy when my stovebolt can manage 10 psi. Maybe we should just average our engines out and we'll both be all set.
Jon 1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#48431 08/02/2005 5:06 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Some of the GMC engines of this vintage had 60 psi pumps. I agree, I would connect another guage and check.
BTW, I've never seen a 20W-40 oil. I/ve been running 20W-50 in the summer, 10W-30 in the winter. Oil pressure in my 235 runs just shy of 40 psi.
The pressure relief valve is part of the oil pump. It could be filled with gunk. First, try going to 10W-30 oil and see what happens. I don't recommend 10W-40, it has an extremely high polymer count and can break down easier than 10W-30.
Fred 52 3600 69 C-10
#48432 08/02/2005 7:36 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I think I'm going to try some straight 30wt oil. If that doesn't do it, I'll pull the pan and take a look at the pump. I installed the pump about a year ago, so if its screwed up its my fault anyway. Thanks guys, Cecil.......... | | |
#48433 08/02/2005 10:03 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | SAE 30 oil will just make the pressure higher.before you pull the pan you might try an old time mechanic trick of adding about 1 quart of Kerosene to the oil to flush everything out good and then drain and replace with fresh oil. | | |
#48434 08/02/2005 5:05 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Baldy-
I meant when compared to the 10W-40 oil. Sorry for the confusion.
