1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48390 07/30/2005 11:04 PM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | When i get to about 40 mph the motor clicks in my 1/2 53 chevy. any ideas? we had to change push rods about 8 months ago. could it be they need to be reset?? I got a new carb about 5 months ago.
thanks slade
If ain't broke Break it and fix it.
#48391 07/30/2005 11:47 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | mine does to but when you get a certain peal pressure it quits. some on this site say if it doen't click you might have a problem. i have no real solution. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#48392 07/31/2005 4:10 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | peal pressure?? is that when the tires stop spinnin? what does 'it clicks' mean? once? every 30 seconds? like a sewing machine? perfectly quiet until you hit 40? what would 'click' in the carb? maybe the valves are too tight Bill | | |
#48393 07/31/2005 4:26 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What engine? Hydraulic or mechanical lifters?
See the USA in your vintage Chevrolet! My Blog | | |
#48394 08/01/2005 3:48 AM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | It clicks like a sewing machine.just like one! really it dont do it exept when you give it gas at about about 35 and when you let off the accelerator it will stop. the engine is a 1956 straight 6 235 with mechanical lifters.
thanks
#48395 08/01/2005 4:36 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 235 should sound like a quiet, well oiled sewing machine - if it doesn't make any noise at all at idle or lower revs, you've got the valves too tight - you may also not be getting good oil flow up top at higher RPM's - check the book and readjust them [well warmed up] to .006 intake, .016-.018 exhaust
Bill | | |
#48396 08/01/2005 6:54 PM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | we adjusted the valves this morning at .008 int. and .016 exh. It still does it but readjusting them made it run alot stronger and pick up speed more not mentioning being more quiet.
#48397 08/02/2005 12:57 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | I have never hAD a 235 that the rockers werent noisy in. | | |
