1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Junior Member
Junior Member
When i get to about 40 mph the motor clicks in my 1/2 53 chevy. any ideas? we had to change push rods about 8 months ago. could it be they need to be reset?? I got a new carb about 5 months ago.
thanks slade
If ain't broke Break it and fix it.
mine does to but when you get a certain peal pressure it quits. some on this site say if it doen't click you might have a problem. i have no real solution. RON
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
peal pressure?? is that when the tires stop spinnin? grin
what does 'it clicks' mean? once? every 30 seconds? like a sewing machine? perfectly quiet until you hit 40? what would 'click' in the carb? maybe the valves are too tight
What engine? Hydraulic or mechanical lifters?
My Blog
Junior Member
Junior Member
It clicks like a sewing machine.just like one! really it dont do it exept when you give it gas at about about 35 and when you let off the accelerator it will stop. the engine is a 1956 straight 6 235 with mechanical lifters.
thanks
a 235 should sound like a quiet, well oiled sewing machine - if it doesn't make any noise at all at idle or lower revs, you've got the valves too tight - you may also not be getting good oil flow up top at higher RPM's - check the book and readjust them [well warmed up] to .006 intake, .016-.018 exhaust
Junior Member
Junior Member
we adjusted the valves this morning at .008 int. and .016 exh. It still does it but readjusting them made it run alot stronger and pick up speed more not mentioning being more quiet.
V
V Offline
I have never hAD a 235 that the rockers werent noisy in.
