1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Truckernix, do you have or do you know where I can get a speaker for a AD slant back radio. I have a straight back in my 53 and just came upon the slant back, I had the speaker reconed but that didn't cure the problem.
Ron | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It has been my experience that a low cost modern 5x7 speaker will fit the slant back radio. Around here you can buy them at Walmart for about $15. I have several if you are stuck. I think most of the specialty vendors carry them but I don't know the price. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | truckernix, have you actually used one of these speakers in a slant back AD radio and it worked? It is my understanding that the speaker in a slant back is different than a straight back, not just in shape but, internal workings. If you have one and it will work in a slant back, I want it! Please e-mail me at [email protected]Thanks, Ron
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | AD_Pickup, there is nothing special about the speaker in either radio. I have used the new speakers in several slant back versions. The difference between the two radios with regards to the speakers is that there is less depth for a speaker to fit in the straight back version. The original spaeakers had a magnet with a smaller diameter but the new speakers that I have seen have a much larger magnet and the frame of the speaker, being at a different angle will not fit inside the straight back version. However, Denny Graham was able to make a new speaker from one of the vendors fit into a straight back model.
By the way, what was the problem that you experienced with your speaker after it had a new cone installed?
I will send you an Email. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Fred & Ron, here is the Classic Parts of America speaker in a straight back 986443: http://good-times.webshots.com/photo/2377603720098611668HiIula Don’t know how much different the slant back is. Denny Graham Sandwich, IL
Denny G Sandwich, IL
