6 members (jmoore, UtahYork, dt235sd, 46 Texaco, cmayna, TUTS 59), 69 guests, and 3 robots.
Topics128,203
Posts1,057,412
Members48,471
I see aluminum water pumps for inline 6 engines on sale on Ebay from time to time and I was wondering if they have any advantages on a street engine versus a stock type cast iron pump.
-ftyler
Only one advanatge I can think of is that they won't rust.
grin
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
weight savings
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
The 292 aluminum ones have an extra, threaded 3/4''npt hole in the top if you wish to run water to say your new intake manifold. I don't believe the 250 alum ones do, but you could add one if desired. There are a couple ways to run water to the intake jacket if needed.
Jim & Caroline
V
V Offline
They are lighter and cheaper to manufacture.No they wont rust but electrolisis will eat away the housing eventually.
