1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I was looking through the sale ads recently and found a Borg Warner OD tranny for sale. They say it came from an AMC and thought it would fit a Ford. I'm hoping to hear from them sometime soon with some casting numbers. What units are I hoping for to fit my 64? Thanks Tramp | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | AMC used the same transmissions as ford. If this is a T5, it can fit many things. However the input shaft would need to be changed to fit the GM pilot bushing, and the input shaft retainer would need to be changed to fit the bell housing hole. If the trans is a really good price, those parts can be found cheep
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is this the old style O-drive behind a 3 speed trans. or a later model 5 speed trans.? Either way I don't believe it will fit. They used different bolt patterns for AMC & ford then GM did. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Most Mfg used a BW OD in conjunction with their own OEM transmissions. Many of the internal OD parts will interchange with other mfg OD units but the basic transmissions are different. Rambler used a torque tube into the mid 60's so as far as I know nothing from them would fit your truck. What you should look for is a Chevy OD trans from 55-65 car or truck and /or a 66-69 OD which is a full syncro. Fred
