4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#48299 07/27/2006 2:55 AM
Looking for any solutions why the engine would stall when I put the transmission in gear. If you rev the engine you can slip it into drive. Also, when coming to a stop the engine stalls. It's a 1978 straight six 250 coupled with a turbo 400 transmission. It starts up and idles fine. No vaccuum lines attached other than the one from the transmission modulator to the intake. Dual points in distributor. It has a new Rochester monojet 1 barrel carb. By the way,its in a 1953 Chevy PU. I welcome all opinions.
#48300 07/27/2006 6:15 PM
any work done on it prior to this problem
Redryder pix
My Hotrod
#48301 07/27/2006 10:51 PM
Riding in the Passing Lane
It could be a bad torque converter or it,s not right for this engine. The 400 was designed for large high torque engines. It soaks up a lot of power. Check for vacuum leaks. The monojet can waller out the gasket between the throttle body & fuel bowl. If the vacuum advance is hooked up to vmanifold vacuum you might change it to ported vacuum & set the throttle idle position up a little.
1972 Chevy c10 Cheyenne Super
#48302 07/28/2006 5:15 AM
2 Offline
Mine had this exact problem. I found that it was as simple as timing, and the two carburetor adjustments (idle speed & fuel/air).
Before assuming your torque converter is screwed up, make sure you find the correct specs and take the half hour to time it right.
Idle Speed: Roughly 550 when in drive with brake on. (Ends up being like between 700-850)
Fuel/Air: Turn screw in all the way towards the carburetor (DO NOT TIGHTEN, carb can break)
back out 3 turns. Start motor. TUrn in the screw slightly to gain best engine smoothness as possible (usually a 1/4 turn in after the 3 turns out).
The timing should be 4 degrees BTDC.
I've seen a lot of people on here say different things about timing that just sounds... well, mroe trouble then it is.
Just go by those specs (or look them up in "The Book" yourself and you'll see that they're right). Either way, timing is the FIRST THING to try for something like this.
1967 Chevy truck "The Hurricane"
WARNING:
This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
