4 members (Nick in Manitou, baldeagle, Lightholder's Dad, Hotrod Lincoln), 50 guests, and 2 robots.
Topics128,014
Posts1,055,333
Members48,419
#482987 12/16/2008 11:24 PM
I'm upgrading my chevy '41 1/2 ton from 6 to 12 volt. Should I change the number of grounding straps I use? When I got the truck, it only had a battery to frame ground strap attached at the engine mount. I'm assuming i should also have an engine to frame grounding strap but was wondering where should i attach it. Thanks.
The more groounds the better, I always say. I have one going to the frame and to the mounting bolt of the starter. You will need a longer cable to do this but I've found it worth while. thumbs_up
Dont forget to run one to the body as well. You may be surprised how much brighter the lights are.....
Brad
cab to frame
cab to bed
engine to frame
i run a ...
radiator frame to frame
inner fender to frame. because i have an electrical relay panel mounted on the drivers inner fender. i also run a pusher fan so that's why the rad frame to main frame.
all this in addition to the bolts that may work holding everything together.
every frame, cable and ground bolt is coated w/ NCP-2, electrical grease.
http://www.batteriesareus.com/index.php?main_page=product_info&products_id=9685
Jim & Caroline
