1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Having a problem with my 51 1/2 ton. Today I was trying to work the gearshift from third to first but it stays in high gear. Took the middle floor cover off to see what was happening and the first and reverse was not being activated, regardless of how much I worked the gearshift. Took the cover off the housing mounted off the unit that is mounted on the steering column and apparently the mechanism isn't going up into the upper gate to operate the lower gears. Is there a way to take the unit off and repair. Hard to see because of the black grease inside it.
Any help is appreciated. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The shifting box on the steering column is the problem, they wear and things don't work right. I have rebuilt several of them by taking them apart and welding onto the forks to narrow the clearance between them to about 1/16". Shift carefully and you shouldn't have problems. If it gets stuck in gear, get out, raise hood and jiggle the shifting arms to get them aligned and then close hood, get back in and shift carefully. | | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Will adjusting the rods affect the operation of the shift box, or is that just to align the gearshift lever in the right position to the steering wheel ? | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Ok, the little "forks" in the box have to be aligned. If you can get your truck out of third(is it in third??? If it is I have had to go through that before and can tell you what someone here told me to do if it is) then you need to take the lid off of the shift box and clean out enough grease to see. Line the grooves of the forks up and it should be aligned after you tighten the bolts on the rod clamps back down.(right beside the shift box on the rods) If it is stuck in third gear and no amount of pulling on the shift rod to get it up helps, jack up the rear end, put some jack stands(not concrete, it could crack and let the truck fall) under the axle and turn the engine over by hand or use the starter. This was the only way to get my transmission unstuck. Hope it helps. You might even be able to relieve pressure on the transmission by moving the wheels a bit. After I got mine out of gear I have had no problem with the three speed/column deal and have started to really like it. | | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Thanks, I will give it a try ! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | As a teen with a 1951 210 and a 1951 1500, I spent a lot of time shaking those shift arms. It wasn't a problem unless I was on a date. I tried to teach my dates to do the shake (the shift arms) but for some reason they refused.
~Jim
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | You might try rocking it back and forth while someone trys to move the shift lever. used to work for me long time ago. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | So did you get it out of gear??? | | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Yes. I did jack up the rear end and that took the pressure off to where I got in neutral. Haven't had a chance to look back at the shift box. I think I will try moving the box around on the column and put in a position where it will be able to go through all gears with no problems. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jordan: Do you have a Factory Assembly Manual? That an a Shop Manual would help you a bunch. Moving the "box" around probably wont' help unless it has moved from original position. Also it should be tight to the column in order to function correctly. mho
~Jim
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | And if anyone is going thru this trouble they ought to replace the shifting forks bushings throughout.
Drew
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Jordan,
One time I tried to remove the shifter cover and when I put it back , I couldnot get neutral and reverse to work. Then I figured the shifter yoks underneath the cover has to align properly so they lock the right gears. I checked from the shop manual and aligned to neutral and then it worked great.
My 2 Cents
Ganesh | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jordan you're going to be a great engineer. Think about Oklahoma State or A&M.
~Jim
| | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Don't have a factory assembly manual. Is it on that website for free manuals ? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't know about that. I bought mine about 3 years ago and don't remember where it came from. I see it at many sites I go to.
~Jim
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Uh, I'm confused. Is JB's 51's name Jordan too or is this a case of mistaken identity. I don't know who you guys are talking to!!! Also, if you can't get an assembly manual, I think that the shop manuals also have the procedure for doing these kinds of things. They can be bought from any of the vendors and it may or may not be on the website for free online manuals. | | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | Sorry 'bout that. I'm John. I just chimed in because I was interested to see about if the information was online or not. Thanks for all the info so far on this subject. Had this truck for a month and trying to cure what few problems I got to get it roadworthy. | | |
