| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i put an ez wiring harness in my 46 i came with a horn relay. i also replaced the steering mast bearing and horn parts in the wheel. is there a way to use the relay in my harness with the old horn button? as i see it now my options are wire the horn up just like gm did and call it good, add an ugly horn button, or make the old button work the relay. any thoughts? philip | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes. use the relay. It is the preferred way. Hook the wire from the button to the B term. on the relay. Hook a hot lead to the B term. Hook the wire from the horn to the H term. Ground the other term on the horn & make sure the relay is grounded. If you are running 6 volts you will need a 6 volt relay. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | are you saying the wire from the old horn button goes to b on relay. or i need a new button? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Use the wire from the original button. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | philip t,
Is your horn also a '46 version...probably. If it has two terminals on it, one will have to be grounded permanently while the other will now get power through your new relay.
Stuart | | |
