3 members (GRNHydra, Gdads51, 1 invisible),
112
Mod | | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48228 07/26/2005 6:32 AM | Joined: Jun 2005 Posts: 16 Junior Member | | Junior Member Joined: Jun 2005 Posts: 16 | I have a 1951 GMC pickup with chevy 235 engine. Oil drips from where the driveline mates to the transmission. I have never worked on a GMC so am not sure if a seal/gasket can be put in without removing the rear-end since it has a closed driveline. Is there information somewhere on this site to help me figure out how to fix this problem? Silver | | |
#48229 07/26/2005 9:00 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Can be done in 30 Minutes without removing the whole stuff. All you need is a new gasket and some silicone. Unscrew the ring that hold the Bell and push it toward the rear end. Remove bolts from the u-joint and the torque tube dropps down. Degrease everything bevore U use the silicone. Good time to do the cork seal of the bell to.
Frank | | |
#48230 07/26/2005 9:13 PM | Joined: Jun 2005 Posts: 16 Junior Member | | Junior Member Joined: Jun 2005 Posts: 16 | Frank, thank you. You have eased my mind a whole bunch. The only closed driveline vehicle I have worked was my 1941 Ford pickup and to drop the driveline you had to move back the rear-end, a lot more work than this is gonna be. Thanks again, Silver | | |
