| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | hi guys getting back to work on the old 54 and i got my front springs back from the machine shop getting new bushings and shackles made.and things are starting to go back together and i was putting the axel up under the springs. then i noticed the driver side has a shim on the bottom of the leaf and the passenger side doesnt.my question is is that shim supposed to be there or not i looked at the bottom of the leaf and the marks look just like the axel.
if it is to be there does anyone have a extra shim
thanks fil
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Those shims adjust the caster. You want the kingpin to tilt back slightly, and using wedge shims between the axle and spring is how you adjust it.
You need to assemble the truck and check the alignment to know for sure whether you need one or not.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | thanks i didnt think of it that way i saw the gap and it got me wondering | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I bought shims at the spring shop where I bought the U- bolts. | | |
