9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#481344 12/12/2008 7:16 AM
hi guys
getting back to work on the old 54 and i got my front springs back from the machine shop getting new bushings and shackles made.and things are starting to go back together and i was putting the axel up under the springs. then i noticed the driver side has a shim on the bottom of the leaf and the passenger side doesnt.my question is is that shim supposed to be there or not i looked at the bottom of the leaf and the marks look just like the axel.
if it is to be there does anyone have a extra shim
thanks fil
Those shims adjust the caster. You want the kingpin to tilt back slightly, and using wedge shims between the axle and spring is how you adjust it.
You need to assemble the truck and check the alignment to know for sure whether you need one or not.
thanks i didnt think of it that way i saw the gap and it got me wondering
I bought shims at the spring shop where I bought the U- bolts.
1949 Chevy 6400
1931 Chevy Firetruck
