| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I need to find a hanging brake pedal set up for my 39 pickup. Any ideas? Ive seen the universal set ups in the mags, but am looking for a set up in the yards. Im sure somebody has done this. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Do you still have the stock stuff around?
The firewall flexs too much to use a uni-mount there
I use and like the stuff from CNC Mfg It's straight forward and strong | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | The pics are nice you sure have done a lot of work. With all that work you have done on the firewall it looks real nice. I haven’t seen a bolt on frame mount for the pre 47’s. I used a 78 Impala it was simple to remove and install. But you are going to have to drill holes in that clean looking firewall. The firewall flex is an issue. I had to run a brace from the bracket to the dash and that stopped the flex. The master and reservoir is all steel and made for a level installation. The booster and master come out a ways and the lines come out on the outside. Inside the swing pedal wanted to come down the left side of the column. I ended up with a collection of half a dozen swing pedal arms with all kinds of bends and angles. I ended up grafting one on to the original swing arm. The right side of the column can get a little busy with the gas pedal.
Don’t over look a Jeep column. The 88 wrangler (YJ) used a GM column lots of Standards but key in column. Maybe an older CJ may have the key in the dash. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I used a hanging pedal and MC from a 69 Nova on my 49 Suburban. All I needed to do was shorten it slightly to mate up with the dash. I'm on the road but could measure length for you if you are interested.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I'm using a booster/mc/proportioning valve/pedal brace from a late '70's/early '80's S-10 in my 1st series '55. The pedal brace needed a little fitting but when bolted to the underside of the dash and the firewall, rigidity is fine. | | |
#4811 10/30/2003 11:00 PM | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | stea, i used a clutch/brake pedal assembly out of a 72 chevelle.It fit perfect from the fire wall to the dash which made it nice and rigid, had to lenghten the pedals 5 inches though...dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
#4812 10/30/2003 11:10 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Thanks guys, Im still hunting, most yards around here only have newer vehicles, all the good old stuff has been sent to the crusher. Guess I just need to pick one and adapt it. Looks like I should be looking for something out of a 60's-early 70's model.
To make matters worse its turned cold and starting to snow. Dont really like to slop through the yards in this weather. But I got to keep feeding the addiction. | | |
