1 members (Otto Skorzeny), 201 guests, and 3 robots.
Topics128,091
Posts1,056,387
Members48,442
#4805 10/27/2003 7:03 PM
I need to find a hanging brake pedal set up for my 39 pickup. Any ideas? Ive seen the universal set ups in the mags, but am looking for a set up in the yards. Im sure somebody has done this.
#4806 10/27/2003 7:28 PM
Do you still have the stock stuff around?
The firewall flexs too much to use a uni-mount there
I use and like the stuff from CNC Mfg It's straight forward and strong
#4807 10/27/2003 7:50 PM
All the stock stuff was gone when i got it, I have smoothed the firewall and it is now 2 layers of metal. I kind of anticipated the flex issue so when i did the firewall i removed the ribbs and then layered another peice of sheetmetel over the original. The two pieces are welded together through the holes created by removing the ribbs.
I also welded a 1 1/4 x 1 1/4 tube from side 2 side in order to brace the pedal assemble and mount the steering column to.
http://www.imagestation.com/picture/sraid83/p957a503b1c2ce6fc4c3d3494b5f25f3c/fadc8206.jpg
http://www.imagestation.com/picture/sraid83/pdfb8233397c383337119c1807a80824c/fadc967b.jpg
#4808 10/30/2003 7:18 PM
The pics are nice you sure have done a lot of work. With all that work you have done on the firewall it looks real nice. I haven’t seen a bolt on frame mount for the pre 47’s. I used a 78 Impala it was simple to remove and install. But you are going to have to drill holes in that clean looking firewall. The firewall flex is an issue. I had to run a brace from the bracket to the dash and that stopped the flex. The master and reservoir is all steel and made for a level installation. The booster and master come out a ways and the lines come out on the outside. Inside the swing pedal wanted to come down the left side of the column. I ended up with a collection of half a dozen swing pedal arms with all kinds of bends and angles. I ended up grafting one on to the original swing arm. The right side of the column can get a little busy with the gas pedal.
Don’t over look a Jeep column. The 88 wrangler (YJ) used a GM column lots of Standards but key in column. Maybe an older CJ may have the key in the dash.
#4809 10/30/2003 9:40 PM
I used a hanging pedal and MC from a 69 Nova on my 49 Suburban. All I needed to do was shorten it slightly to mate up with the dash. I'm on the road but could measure length for you if you are interested.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#4810 10/30/2003 9:56 PM
I'm using a booster/mc/proportioning valve/pedal brace from a late '70's/early '80's S-10 in my 1st series '55. The pedal brace needed a little fitting but when bolted to the underside of the dash and the firewall, rigidity is fine.
#4811 10/30/2003 11:00 PM
stea, i used a clutch/brake pedal assembly out of a 72 chevelle.It fit perfect from the fire wall to the dash which made it nice and rigid, had to lenghten the pedals 5 inches though...dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
#4812 10/30/2003 11:10 PM
Thanks guys, Im still hunting, most yards around here only have newer vehicles, all the good old stuff has been sent to the crusher. Guess I just need to pick one and adapt it. Looks like I should be looking for something out of a 60's-early 70's model.
To make matters worse its turned cold and starting to snow. Dont really like to slop through the yards in this weather. But I got to keep feeding the addiction.
