8 members (Nick in Manitou, tclederman, papas52, Robert Crandall, MikeStone1953, Gray_Ghost, Grizzly 34s, 66flea),
65
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | This is probably a stupid question but...I have no idea what 3 bolt holes are for on the driver's side of the engine ('54 235). Nothing was attached to them when I got the truck. They're in an upsidedown triangle pattern. The upper 2 are about 9 - 10 inches from the front of the engine and 4 inches above the pan. The lower one is located below these 2 about 1 1/2 inches above the pan. Thanks | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | Do they look like this: 1953 side engine mounts This block came out of a 1953 car with powerglide, the first 235 to have pressurized oiling. The holes here were for side engine mounts. I don't know if all blocks got the holes after that time or not. My 1957 Truck motor does not have them. I might hazard a guess that they are only on blocks for cars not trucks. | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Those holes are for side engine mounts when the block is paired up with a Powerglide transmission in a passenger car. The PG had a rear mount that fit on a crossmember atr the rear of the transmission, and no bellhousing mounts like a 3-speed standard transmission. Hanging the engine/trans assembly by front and rear put too much stress on the bellhousing, so the front mount was moved to a mid-engine position. I'm restoring a 51 2-door hardtop with that mount setup right now. Jerry
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Funny you ask . . . I had the same question! We're about to re-install a 216 (I think it's a '46) and I can't remember for the life of me WHAT mounted to those holes!!! I think - nothing. 216 mounting holes -Michael | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I felt silly asking, but thanks to everyone for the answers. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The '56 Chevy 2-ton I pulled my Yard Dog's engine out of had side mounts. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | I believe that all of the 1952-54 passenger cars had the side engine mounts being discussed. I had a 1953 Chevy 210 with a standard transmission and several 54 261s that all have the mounts. Some were not drilled and tapped. They are great mounts, but they take up a lot of space. 49-54 Shop manual parts manual Hoyt | | |
