Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (UtahYork, klhansen, Otto Skorzeny, carbking, SNOYL, ndkid275), 108 guests, and 2 robots.
Topics128,286
Posts1,058,539
Members48,491
Anyone know where I can get replacement isolators for my 62' C10 at the crossmember for the torsion bars? Mine are looking pretty old and since I'm down to a bare frame, it's a good time to replace them.
Well, I figured out a way to make isolators for the torsion bar crossmember. I wandered thru the auto parts stores and found the aftermarket expandable freeze plugs. It was the correct diameter with a 3/16 hole in the center. I drilled that out to match the 1/2 diameter compression limiter from the old isolator and inserted a 1/2 wood dowel for a handle and cut it on the band saw to the same thickness as the old one. I was able to make 1 set of 2 isolators from one freeze plug which cost $2.99.
