1 members (Jon G),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 17 Member | | Member Joined: Dec 2001 Posts: 17 | I have a 55 3100 series chevy with a 350 v8 what expense and problems is there in converting to power steering? Also would like to do the same with the brakes. Help thanks. | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Steering Expenses: 1. steering box and bracket 2. hoses and pulley 3. steering u-joints and Double D shaft 4. Column if not using original 5. power steering pump and bracket
I would think your only problem will be clearance between the engine and steering box if you go with a kit that mounts the box on the engine side of the frame by the exhaust manifold. I would go with the kit that mounts the box on the outside of the frame ahead of the axle. You'll have to cut an access hole for the steering shaft to pass through up to the column. Several vendors sell the v-8 power steering brackets and hoses.
The power brakes kit can be purchased from several vendors which mounts the booster/master cylinder under the floor.
Expenses for this conversion are: 1. booster/master cylinder kit with bracket 2. new lines 3. adjustable proportioning valve and residual pressure valves "depending on disc/drum set-up" 4. change exhaust pipe routing by booster.
Joe
| | | | | Joined: Dec 2001 Posts: 17 Member | | Member Joined: Dec 2001 Posts: 17 | Thanks for the information joe. Now all I have to do is find the time. By the way how do you like your truck? Thans again. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | if you want to spend big bucks go to www.flamingriver.com they make an electric that bypasses the extra pump.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | FATBOY58, search my posts on my power front disc conversion. i bought a total kit for right at 1 grand. lots of headaches, but the end result was worth it.
leonard | | |
