Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Shaffer's1950, Hanks custodian, Wally / Montana), 106 guests, and 7 robots.
Topics128,283
Posts1,058,519
Members48,490
Are the distributors on a 1953 GMC and Chevrolet interchangable? I would think so but the changed so many things from the 216 to the 228 I would like to ask the pros.
Thanks.
Yes, more or less. They fit mechanically but may have different advance curves.
Also, in either engine you have to make sure you have the correct gear for the camshaft material you are using (steel or cast iron) to avoid excessive wear.
The GMC 6's use the same cam bearings and cam blanks as the small journal (216/early 235) Chevy engines as well.
Paint & Body Shop moderator
