8 members (Wally / Montana, cmayna, 49nut, Hotrod Lincoln, GRNHydra, HandyAndy, Leo, 1 invisible),
128
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Ok, I'm new to this game, but I have been around the block a couple of times. The production numbers furnished on the Suburban vs Panel post has got me wondering. Obviously the difference between a Panel and Suburban are rather obvious, but what exactly is a Carryall? I was told once that the early Suburbans were called Carryall's, but yet the production numbers show that the 4x4 Burbs were Carryall's. I have also seen Suburbans that had fixed windows down the side of them, not the sliders. Is this a differant model, or were the Sliders just an option? | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | You will also see a Carryall Suburban and a Suburban Carryall!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Well,,, heres my take on the subject. Its probably not right but it kinda makes sense to me. A panel is just that. A panel truck! Good for delivery,freight purposes. A suburban, to me is the suburban with the seats in it,to where it can be used as a "passenger vehicle",,,Station Wagon. A suburban with the seats removed would be a "carryall". Obviously for "carrying" cargo,freight,parcels,lumber,etc..... Who knows for sure???????????????
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | if the 60-66 Suburban had the last (second) fixed window that was because it was ordered with only two seats. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I bought my 63 Suburban from the original owner and he ordered it to be a true utility vehicle. It came without the narrow middle seat and the rear side windows are fixed instead of sliding. The wide rear seat is where the middle seat would have been. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | In the Task Force era. Chevy had among it's styles, a Suburban and a Cameo and GMC called the same two: Carryall and Suburban Carrier.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
