6 members (Jay R, TUTS 59, Otto Skorzeny, kades51, Cosmo, treegrower), 49 guests, and 2 robots.
Topics128,023
Posts1,055,365
Members48,420
#47883 07/19/2005 3:54 AM
Junior Member
Junior Member
I'm thinking of buying a 235 from a 55' chevy. From the pictures it appears the front motor mounts are side mount style. My question, will the side-mount motor work in my 54' with front mounts?
#47884 07/19/2005 4:05 AM
Yes, you will just have to drill some holes in the timing chain cover to use the front mounts or install a 216 timing chain cover on your new motor. I got my new 235 installed and then drilled up from the bottom. Worked great. Good luck.
