2 members (baldeagle, 1 invisible),
90
Mod | | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47883 07/19/2005 3:54 AM | Joined: May 2003 Posts: 13 Junior Member | | Junior Member Joined: May 2003 Posts: 13 | I'm thinking of buying a 235 from a 55' chevy. From the pictures it appears the front motor mounts are side mount style. My question, will the side-mount motor work in my 54' with front mounts? | | |
#47884 07/19/2005 4:05 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Yes, you will just have to drill some holes in the timing chain cover to use the front mounts or install a 216 timing chain cover on your new motor. I got my new 235 installed and then drilled up from the bottom. Worked great. Good luck. | | |
