8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#478655 12/05/2008 5:06 AM
Ok, I'm new to this game, but I have been around the block a couple of times. The production numbers furnished on the Suburban vs Panel post has got me wondering. Obviously the difference between a Panel and Suburban are rather obvious, but what exactly is a Carryall? I was told once that the early Suburbans were called Carryall's, but yet the production numbers show that the 4x4 Burbs were Carryall's. I have also seen Suburbans that had fixed windows down the side of them, not the sliders. Is this a differant model, or were the Sliders just an option?
You will also see a Carryall Suburban and a Suburban Carryall!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Well,,, heres my take on the subject. Its probably not right but it kinda makes sense to me.
A panel is just that. A panel truck! Good for delivery,freight purposes.
A suburban, to me is the suburban with the seats in it,to where it can be used as a "passenger vehicle",,,Station Wagon.
A suburban with the seats removed would be a "carryall". Obviously for "carrying" cargo,freight,parcels,lumber,etc.....
Who knows for sure???????????????
RJ Offline
if the 60-66 Suburban had the last (second) fixed window that was because it was ordered with only two seats.
I bought my 63 Suburban from the original owner and he ordered it to be a true utility vehicle. It came without the narrow middle seat and the rear side windows are fixed instead of sliding. The wide rear seat is where the middle seat would have been.
Sir Searchalot
Sir Searchalot
In the Task Force era. Chevy had among it's styles, a Suburban and a Cameo and GMC called the same two: Carryall and Suburban Carrier.
