5 members (FishinToms53, Peggy M, Gib70, Southerntruck, 1 invisible), 145 guests, and 2 robots.
Topics128,089
Posts1,056,433
Members48,443
#47852 07/18/2005 9:33 PM
I have a 1954 3100 that is leaking trans fluid into the rearend. I was going to buy the parts and bushing puller from a vender only to find the puller is not available from any one that I could find. My question. Is this a special puller or will I find one at a rental yard? I really do not want to pull the whole rearend and take the drive shaft apart. Any thoughts or help would be great.
Steve :confused:
#47853 07/19/2005 1:07 AM
A standard slide hammer with a bolt head ground a bit to fit between the driveshaft and bushing has worked for me. Reinstallation is easy, block of wood and hammer.
#47854 07/19/2005 6:02 AM
hourhand,
I found the easiest way was to get the puller. You can find one directly from the manufacturer here..
http://www.vapinc.com/
do a search on
part#V-100
Driveline Bushing Puller
Or if you have problems I am willing to part with mine for a little cheaper.
good luck!
#47855 07/19/2005 6:47 AM
Chev235,
Thanks I tried Vintage Auto Parts they are out with none on order.
Steve
