| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47852 07/18/2005 9:33 PM | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I have a 1954 3100 that is leaking trans fluid into the rearend. I was going to buy the parts and bushing puller from a vender only to find the puller is not available from any one that I could find. My question. Is this a special puller or will I find one at a rental yard? I really do not want to pull the whole rearend and take the drive shaft apart. Any thoughts or help would be great. Thanks Steve :confused: | | |
#47853 07/19/2005 1:07 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | A standard slide hammer with a bolt head ground a bit to fit between the driveshaft and bushing has worked for me. Reinstallation is easy, block of wood and hammer. | | |
#47854 07/19/2005 6:02 AM | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | hourhand, I found the easiest way was to get the puller. You can find one directly from the manufacturer here.. http://www.vapinc.com/ do a search on part#V-100 Driveline Bushing Puller Or if you have problems I am willing to part with mine for a little cheaper. good luck! | | |
#47855 07/19/2005 6:47 AM | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | Chev235, Thanks I tried Vintage Auto Parts they are out with none on order. Steve | | |
