0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | I am interested in using this intake but not sure as to which carb to run. I would think that a 600 cfm would be about right but was wanting input on what others have or are using. | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | My GMC 302 has a 400 CFM Carter AFB. Works good.
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | first of all, what engine is this for?
I have a clifford 4bbl intake with a holley 390cfm carb on my 54 235 thats in my 52 Chevy 3/4 ton pickup. As recommended by clifford I made some changes to the carb. So far so good, have yet to get it on the road but I have no doubts that it will do just fine. Just needs a bit of tuning yet. | | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | its a 235 but the later model 58-62. plus i am running a t-5 with an s-10 rear end-. so i am trying to get a little more performance-thought about the dual carb set-up but i like what i saw on youtube with the 4 barrel | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | my old man run,s a 4360 holly it's 450 cfm on his 1940 1/2 ton w-235 and clifford intake fenton header's water heated carb spacer ,it work's great . Ive got one on a 292 on a offy intake it gives plenty of gas .any thing much bigger and it will be over carbed .unlessed it is camed up . | | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | A 235 running @ 5000 RPM at 100% volumetric efficiency needs at least 340cfm. (VE x RPM x CID / 3456) How fast will your 235 spin? How efficient is you cylinder head and intake? How aggressive is the cam? That's probably why everyone is reporting good results with the 390 - 450 size carbs
regards, Leon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Clifford used to have a CFM rating calculator and I recall that it rated a 261 at about 350 CFM (but my memory might be off).
Clifford's site suggests a minimum of 350 cfm and they sell a 390 cfm Holley for that intake (or, a Weber 38 - 390/400 cfm).
