1 members (Bill Hanlon), 143 guests, and 3 robots.
Topics128,089
Posts1,056,116
Members48,434
#478410 12/04/2008 7:49 PM
I am interested in using this intake but not sure as to which carb to run. I would think that a 600 cfm would be about right but was wanting input on what others have or are using.
My GMC 302 has a 400 CFM Carter AFB. Works good.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
first of all, what engine is this for?
I have a clifford 4bbl intake with a holley 390cfm carb on my 54 235 thats in my 52 Chevy 3/4 ton pickup. As recommended by clifford I made some changes to the carb. So far so good, have yet to get it on the road but I have no doubts that it will do just fine. Just needs a bit of tuning yet.
its a 235 but the later model 58-62. plus i am running a t-5 with an s-10 rear end-. so i am trying to get a little more performance-thought about the dual carb set-up but i like what i saw on youtube with the 4 barrel
my old man run,s a 4360 holly it's 450 cfm on his 1940 1/2 ton w-235 and clifford intake fenton header's water heated carb spacer ,it work's great . Ive got one on a 292 on a offy intake it gives plenty of gas .any thing much bigger and it will be over carbed .unlessed it is camed up .
thanks for the info
Carburetion specialist
Much depends on other engine mods (specifically camshaft). I ran a Carter 400 on a stock 300 CID Ford and it was plenty.
This article may help:
http://www.thecarburetorshop.com/Carburetorsizeselection.htm
Or possibly this one:
http://www.thecarburetorshop.com/Carbshop_carbsizesandCFM.htm
Jon.
The Carburetor Shop
A 235 running @ 5000 RPM at 100% volumetric efficiency needs at least 340cfm. (VE x RPM x CID / 3456)
How fast will your 235 spin?
How efficient is you cylinder head and intake?
How aggressive is the cam?
That's probably why everyone is reporting good results with the 390 - 450 size carbs
regards,
Leon
Clifford used to have a CFM rating calculator and I recall that it rated a 261 at about 350 CFM (but my memory might be off).
Clifford's site suggests a minimum of 350 cfm and they sell a 390 cfm Holley for that intake (or, a Weber 38 - 390/400 cfm).
