4 members (Donf, FAST55, Shaffer's1950, greenie-reddy), 34 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
#478177 12/04/2008 4:25 AM
Hi,
I'm looking for a bit of info.. On the AD trucks whats the hole size in the dash for the dual round gages? And how far apart are the 2 holes?
Any one have a bare dash they could measure?
On my '49, the gauge holes are 5-1/4 inches in diameter and 6-13/16 center-to-center.
I am not sure what you are asking. If you are adding aftermarket guages to your dash, the diam. of the guage is in the installation pkg. you get with the guage set. For me an under dash setup is the way to go, but I like to keep the dash as near origional as possible. If you are building a street rod or somthing custom then I see your need for guage size.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
I had some metal rings cut out so I could install a 5" AutoMeter Tachometer and Speedometer in my 52. 5-1/4 is correct. I had the rings machined with an outer diameter of 5-3/16 so that there would be the proper amount of gap to weld them in. They worked perfectly.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=467155#Post467155
