Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#47824 07/18/2005 8:05 PM
Just did a search, and didn't find what I have seen before, I have the Rochester B 1bl carb, and it starts and runs good, but seems that it's running a little rich..Looked in my manual, and it was saying to turn in the adjustment, and back out 1 1/2 -2 1/2 turns..Really don't want to do that..My question..should I turn it in until it starts to stall, and back it off, or should I turn it until I get the best idle speed? Thanks
#47825 07/18/2005 8:18 PM
are you speaking of the idle on the carb? because you stated you did not want to mess with,,,, if it is running like you want it to I would not mess with it, I did increase my idle about 250 rpm to about 800, seems to like it better their,,go google for this site ,Recarbco, I have trouble with the copy and paste,,,it is a good site with a lot of good carb tips. I got mine re-done by them about 2yrs ago,,see ya........Fred
Redryder pix
My Hotrod
#47826 07/18/2005 8:34 PM
Thanks Fred..Already went outside and messed with it..Have adjusted idle speed before, and usually keep mine about 800rpm, but was messing with the air/fuel adjustment, because it seemed like it was running a little rich..Hope I didn't screw it up, but seems to be running OK..Guess it's time for a test drive..Later, Steve
#47827 07/18/2005 8:37 PM
V
V Offline
You run the fuel/air screw in till it stops then back it out 1 1/2 turns then start the engine and turn the screw in and out about 1/2 turn at a time to get the best idle then leave it alone.
#47828 07/18/2005 8:46 PM
Thanks V6, that's what I need to know, Steve
#47829 07/18/2005 10:10 PM
Riding in the Passing Lane
I adjust it by turning it in slowly till the engine starts to slow down than back it out till it smooths out usually about 1/2 turn. That is the idle mixture. if it is too rich running down the road check the float level. You may have to go to a leaner main jet. On my 235 I run a .055 jet. It had a .053 but was a little lean.
1972 Chevy c10 Cheyenne Super
#47830 07/18/2005 10:33 PM
Thanks, it runs good, but the exhaust pipe is black, and it smells rich..The carb is a bebuilt and have never had a problem, just wanted to save a little mpg..Steve
#47831 07/19/2005 3:59 AM
My exhaust is a little sooty too. I'm running a .054 Jet. I'm in the Mile High City so should I put a leaner jet it it. Shooper, do you know what jet size your running? What's the altitude there? That may be a factor.
#47832 07/19/2005 2:17 PM
There are other things that can go wrong inside that carb. Running rich will carbon up your valves and you don't want that. There is a power piston inside that allows more fuel flow when the throttle opens and the vacuum is lowered. If that hangs up, you can have a rich mixture problem.
1951 1 Ton Completed
